Home1mz build and install blog1mz build and install blog1mz build and install blog1mz build and install blogToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
blogging, work, give, injectors, changed, stock, manifold, adjusted, disturbertor, re-adjusted, timing, plugs, blogs, spark, 2709918950, checked, call, rpms, reason, 3,000rpms, 2,000, sensor, problem, ended, intake, gettin, helpp, forum, awsomee, guys, site, 15lb, back, runs, fine, valve, fuel, rail, blocked
new here to the forum awsomee site guys
well here is my problem i own a 91 mr2 N/A
i ended up gettin a jdm intake manifold and 15lb injectors well i put everything on and it wouldnt work i changed the fuel rail and blocked the egr valve that didnt work so i went back to the stock injectors and stock manifold and its still blogging
it runs fine but as soon as i give it some gas it blogs down i changed the
