5S-FE MK2 Non-Turbo Engine 5SFE Advanced Ignition Timing Problems
5S-FE MK2 Non-Turbo Engine, timing, ignition, slow, degrees, give, encountered, connected, wire, spark, detonation, drops, idle, erratic, slightly, drop, rise, made, mark, properly, sync, cylinder, firing, belt, figure, connection, jumped, diagnostic, advise, dizzy, dial, select, 0-60, left, worked, today, boost, read, advancing, problems, advanced, btdc, power, slight, tiny, clockwise, 5sfe, decided, turn, degree
Hey, I read that advancing ignition timing to 14 degrees BTDC would give me a slight power boost so I tried it out today. The timing gun I used had a dial to select 0-60 degrees, but I wasn
