size, bolts, brake, stuck, alot, holes, couple, appreciated, tricks, hardware, store, minutes, tips, replacing, rotors, front, rotor, warped, nuts, luck, surface, beating, hammer
I need some help. My front brake rotors are seriously stuck. I am replacing them as they are warped. I have tried beating them with a hammer on the hub hat and the surface between the lug nuts with no luck. Should I try to put a couple bolts in the two holes? If so, what size bolts would I use. If I know what size I have a hardware store 5 minutes away. Any tips and tricks would be appreciated.
Thanks alot.
