AI智能索引来源:http://www.mr2.com/forums/threads/41401-Axle-help
Axle help.....
axle, pull, back, good, shaft, boot, piece, grease, in/on, call, clamp, basically, bearings, amount, grateful, experience, dave, axles, taking, pipe, wiped, inspect, guess, advice, tips, lucky, rear, side, passenger, attached, seal, remove, managed, succeed, folded, closed, carefully, reseal, push, close, reuse, pulled, thing, place, main, huge
    So by trying to remove my hub, which I did succeed, I managed to pull the axle apart.....doh. Its the passenger side rear axle (just fyi) and is still attached. Anyway, I took the outside seal on the boot off, folded the boot back....still looks good and will probably reuse it. Looks like I pulled the axle hub thing off the main shaft. The pin is still in place so it looks like I got a lucky pull while the pin was closed in and it just came off. Can I just very carefully close the
