AI智能索引来源:http://www.mr2.com/forums/threads/42292-ITB-question
meet, itbs, piston, 4-mahle, 5-head, rings, bolts, 3-arp, gasket, head, 2-acl, picks, post, bearings, machined, ported, hyabusa, picked, heard, polished, today, things, 1-copper, good, stock, time, project, thinking, setup, 3sge, turbo, question, fellas, failed, custom, ecu,timing, rail, ports, injector, flange, cable, throttle, pipes, welded, build
    .....All right fellas.. I was the guy with the failed turbo 3sge... So new project time...... Im thinking ITB setup but im not sure what I need to run them.. I know custom throttle cable, flange needs to get welded with pipes to meet the ITBs, injector ports need to meet rail,.... can I run the stock ecu,timing? So far this is what I have for the build 1-copper head gasket 2-ACL rod bearings 3-ARP rod Bolts 4-MAHLE piston rings 5-Head is getting machined and Ported polished 6- Im going
