Homehttps://www.facebook.com/groups/272473382858001/Visit HomepageVisit Homepagehttps://www.facebook.com/groups/272473382858001/Kazoku Wagon.Because Racecar.Toyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
stay, e-brake, rear, replaced, light, turn, pump, times, couple, pedal, malfunctioning, brakes, back, moment, rear-brake-related, problem, switch, replace, pressure, hard, cable, tension, calipers, rebuilt, checked, stays, issue, dash, released, pads, fluid, lines, rotors
- I was having an issue where when I released the e-brake the dash light would stay on. I checked the tension on the cable and it seemed ok, so I replaced the rear calipers with rebuilt ones, replaced the rear pads, rotors and while i was at it put new SS lines and fluid all the way around. It seemed to go away but now if I
