T3/T4 External Wastegate Write-Up
turbo, exhaust, back, pipe, wastegate, manifold, external, lines, bought, temp, line, adapter, parts, close, fitting, block, boost, dump, bolts, work, plate, bolted, made, part, racing, inlet, fitment, flange, its, water, left, gauge, t3/t4, hook, existing, sandwich, controller, vacuum, easier, section, completely, reliable, dyno, decided, problems, bottom, internal, future, degree, side
So when I was looking for a MR2, I wanted one that was kind of beat up and needed some work. A project car that would one day run on the track. My reasoning? Well, I would be replacing or upgrading most of the parts anyways, so why buy ones that worked.
I found my Deuce, bought it for 2,500, brought it home and began. The first major upgrade: rebuilding the turbo that was leaking oil. Struck by Murphy
