AI智能索引来源:http://www.mr2.com/forums/threads/44267-92-mr2-running-rough
92 mr2 running rough
sensor, plug, voltage, coolant, system, volts, pressure, simply, back, kicking, computer, temp, drops, time, blead, apparently, bought, correctly, appericeated, greatly, thermostat, atmospheric, overheated, codes, idle, engine, vaccum, entire, redo, replaced, rough, running, picked, friend, checked, diagram, messed, lean
    i picked this car up from a friend who replaced the engine with another one just like it. i had to redo the entire vaccum system he had it all messed up according to the diagram and that didnt help it. when i plug the map sensor up it seems to lean out some but the idle goes up to about 2k. i checked the map sensor voltage i have 5v at the cpu and 5 at the plug under atmospheric pressure when i simply plug the map back in the voltage drops to 3 volts. is that right? the computer is kicking the
