AI智能索引来源:http://www.mr2.com/forums/threads/44343-Need-help-with-Ignition%21%21-91-N-A
Need help with Ignition!! 91' N/A
distributor, hesitation, ignition, spark, surge, rpms, band, higher, problems, coil, plugs, track, wires, rotor, thinking, replacing, hard, ideas, 2.5k-3.25k, light, throttle, system, problem, pressure, engine, lose, power, stops, pulling, 5.5k, past, hesitate, acceleration
    So i have a little problem with my ignition system it seems. between 2.5k-3.25k RPMs under light throttle pressure my engine seems to hesitate and surge a bit during acceleration, and once past 5.5k RPMs i seem to lose a bit of power (stops pulling as hard). but under WOT i have no problems..until of course i get to the higher rev band. Any ideas? I was thinking of replacing the coil, distributor cap, rotor, wires, and plugs...am i on the right track here??
