idle, running, 1100rpm, idle.when, idles, screw, throddlebody, start, belt, tripping, codes, suggestiong, leaking, possibly, tore, squeeks, waterpump, 2000-2500rpm, 1100, plug, in,got, timing, unplugged, sensor, diagram, high, lines, vacuum, pluged, loose, reran, plugs
ok this car had the map sensor unplugged when i got it i plug it in,got the timing best i can considering i cant get idle under 1100 i dont know if its right or not pluged up a few loose plugs reran the vacuum lines according to the diagram and now it wants to idle at like 2000-2500rpm i ran the screw on the throddlebody almost all the way in and now it idles at 1100rpm? its running much better than it was its just the idle.when i start it the belt squeeks i havent tore into it to see if the
