AI智能索引来源:http://www.mr2.com/forums/threads/44880-Alternator-Belt-Adjustment-Issue
5S-FE MK2 Non-Turbo Engine Alternator Belt Adjustment Issue
adjusting, alternator, belt, 5S-FE MK2 Non-Turbo Engine, bracket, motor, brakes, pulled, seals, issue, clutch, bolt, engine, removing, sleeve, service, leak, install, dropped, knowing, $600, simple, wrong, adjustment, tight, slot, lock, short, nice, today, pull, advance, removed, remember, press, thumb, closer, middle, socket, clearances, removal, deflection, life, pain, bringing, retrieve, shop, linkage, assume, greatly
    Hi All! Very new to the MR2 world, just picked up a 91 NA 5S-FE after driving my sons 87 NA, very fun cars! Now to the not so much fun stuff... Bought the car knowing it had an oil leak, needed brakes, and clutch was slipping. Body was straight with no dings, interior complete and clean, just missing the shift boot cover and plastic trim around the short throw shifter. $50 on ebay and those are done. New brakes, calipers, and rotors all around, done. Engine I will drop this winter and
