noise, clicking, start, good, type, terminal, negative, battery, weeks, tested, 2000, time, happened, spyder, stamped, figuring, messing, coincidence, lead, cigarette, lighter, fired, accessories, pannel, days, couple, side, left, work, turning, make, fuse, started, dpoing, today, ignition, replaced, back-, lighst, disconnect, till, this-, clean, regular
I have a 2000 spyder. 3 weeks ago it started dpoing this- lighst and all accessories work, but turning the ignition just make a clicking noise in the fuse box on the left side pannel. For a few weeks, every other couple days it would do this, till I disconnect the negative battery terminal and clean it and put iyt back- then it would start right up.
SO today I replaced the negative terminal with a regular lead type instead of the stamped type, figuring that would fix it for good. No all I
