AI智能索引来源:http://www.mr2.com/forums/threads/45085-5sfte-problem%21-plzzz-help-asap%21
5sfte problem! plzzz help asap!
give, revs, problem, spooling, guessing, open, closed, gate, waste, turbo, re-posted, mods, section, deleter, confused, plzz, pipe, resonator, exhaust, drive, test, gear, today, asap, plzzz, guys, installed, slowly, stays, spool, 0psi, gauge, boost, pass, back, 5sfte, 5sfe, vacumm
    hey guys i installed everything today and took it for a test drive. the car revs up with no problem. but when you put in gear and give it gas it wont let you. it just revs very very slowly and wont pass 3k. is my map bad? i put back the 5sfe map and tried and nothing. my boost gauge also does not spool. stays at 0psi and when i give it gas it gos into vacumm.
