Suspension Repair Question
forward, bolt, mount, frame, suspension, plate, side, front, shift, place, brace, welded, hole, wheel, slightly, damage, back, side-load, designed, play, geometry, previous, appears, repair, work, aimed, threads, engage, wide, alignment, striped, question, sort, allot, placing, forced, owner/repairman, rear, re-tap, mounts, allowed, lower, control, meat, removed, spread, affected, turn, side-loaded, handling
I have a 91 MR2 that has had some sort of damage to the drivers side front suspension. I
