AI智能索引来源:http://www.mr2.com/forums/threads/46815-RPMs-rev-high-but-takes-a-while-before-it-starts-speeeding-up
RPMs rev high, but takes a while before it starts speeeding up...?
barely, problem, clutch, high, worse, shift, press, needing, replacement?confused, moves, belt, revs, pedal, starts, speeeding, takes, rpms, replacing, told, timing
    idk wut the problem is. some told me that the clutch needs replacing, or the timing belt. but the problem is getting worse. wen i shift, i barely press the gas pedal and it revs high but the car barely moves. would this be the clutch needing replacement?:confused:
