AI智能索引来源:http://www.mr2.com/forums/threads/48190-low-temp-issues
low temp issues.
start, problem, plug, drive, rotor, stop, dead, major, stutters, acceleration, problems, slow, miss, warms, sort, swap, plan, thinking, work, gotta, cash, injector, coil, gonzo, rpms, comp, power, cold, replacing, lack, cylinders, plugs, wires, gasket, bieng, compression, cover, valve, issues, temp, replacements, 5s-fe, seals, tube, spark, adding, distributor, noticed, 14.9, seal
    I just did a few replacements on my 5s-fe, being spark plug tube seals, valve cover gasket, plug wires, plugs, cap and rotor. I know cylinders 3-4 have bad compression bieng around 50 dry and up to 100 with adding oil, and that the timing is right at 10*BTDC with e1 and te1 jumped, the coils primary resistance ran at .6 ohms, no good,secondary was at 14.9. Also noticed a bit of oil under the distributor cap right around the cap seal, none on the cap terminals or rotor at all. heres the
