AI智能索引来源:http://www.mr2.com/forums/threads/48406-Aaron
place, aaron, hold, bolts, site, previous, orders, gave, illustrations, vehicles, info, joel, longer, part, actual, washer, cross, member, clip, belive, brackets, rear, sway, flow, bolt, pulley, idle, meter, plug
    Hi Aaron, I need the brackets and bolts that hold the rear sway bar in place (i belive it bolts onto the cross member), the clip that hold the Air flow meter plug in place and i also need the ac idle pulley with the bolt and washer if there are any. I tried to go to the web site that you gave me in one of my previous orders to get you the actual part #
