Passenger Side Power Window
wires, window, back, work, side, closed, power, passenger, rolled, worked, matter, causing, connections, connected, service, working, manual, find, read, moving, connection, messed, http://img41.imageshack.us/img41/8271/img00503.jpg, shot, glovebox, bottom, found, green, blue, halfway, bought, drivers, taped, door, cover
when I bought the car, the passenger Side Window never worked
well I got to the bottom of that and found two wires cut under the glovebox
if you can see it in the shot, the green and blue wires
when I put them back together and tried the power window.. it worked, on the drivers side, I taped them up and put the cover back on, closed the door and it didnt work yet again, and was halfway rolled down
after I messed with the wires some
