test, noise, shafts, making, forward, suggestions, moving, information, shifting, shaft, advance, sounds, possibly, causing, thinking, shot, rear, front, motor, mounts, slamming, determine, light, engine, check, jumping, running, connectors, questions, quick, fairly, normal, idea, easy, knob, turned, time, jerks, resets, lights, close, left, headlights, turn, illuminate, accs, position, adjust, permanently, makes
these should be fairly easy but i have no idea if it is normal or not
1) does the check engine light ever come on with you jumping the connectors? i have had my car running really bad before and its never come on before but it does illuminate when you turn the key to
