AI智能索引来源:http://www.mr2.com/forums/threads/54254-pfc-idle-issues
pfc idle issues
sensor, dies, readings, running, datalogit, equally, touch, apexi, throttle, light, release, give, week, idea, hafsteinn, wrong, shop, idling, user, move, power, sensors, oxygen, installed, vta2, issues, good, engine, heat, 4.95v, bost, start, idle, starts, revs, great, 0.02v, dots, highlighted
    Hello, im a new user with the apexi power fc, ive installed my ecu and gm mat sensor gm map sensor and engine lid heat sensor, all the readings V readings are good i got 3 sensors out, 02s( oxygen sensor ?), VTA2 is at 4.95V and Bost is at 0.02V then i got IDL , ELD and FPR has highlighted dots but when i start the car up it starts great and revs to around 2k and dies, if i touch the throttle light it dies, but if it give and release the gas equally it keeps on running but then dies as
