AI智能索引来源:http://www.mr2.com/forums/threads/55681-3rd-gen-mk2-with-haltech-ems-help-needed
3rd gen mk2 with haltech ems help needed
knock, voltage, haltech, reading, event, sensor, load, timing, base, high, sort, running, tuning, street, idea, areas, pump, turbo, times, read, mods, degrees, stock, readings, control, ballpark, higher, adjustments, input, trims, fuel, assign, steady, misread, 1/10th, software, datalogging, fluctuating, 300-400rpm, free, connected, concern, revving, holding, function, occured, block, hammer, case, turbo/wastegate/intake/exhaust
    hi everyone, my friend and i recently put a haltech platinum sport 1000 (which doesnt have knock control) in his nearly bone stock 94 jspec mr2. the only mods on the car are a 3 inch intake with a 9inch k&n, some aftermarket exhaust that is higher than normal flow but still quiet(i forgot the brand) and a downpipe. we are still unsure what sort of target afr
