5S-FE MK2 Non-Turbo Engine Clutch hydraulic problem.
clutch, cylinder, hydraulic, mr2, slave, 5S-FE MK2 Non-Turbo Engine, pressure, problem, fluid, change, bleed, bleeder, brake, master, system, slow, driveway, leaking, causing, applies, trickle, bubbling, plug, loosen, expand, bone, reservoir, checked, threw, couple, work, backing, sign, coming, reverse, taking, times, looked, what-so-ever, lost, lines, changed, seconds, dot-3, blowing, worked
First sign of problem was backing out of my driveway. There was a car coming so I tried taking the mr2 out of reverse. It didn
