HomeVisit Homepage1mz build and install blogVisit HomepageVisit HomepageVisit HomepageVisit HomepageVisit HomepageVisit HomepageToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
5S-FE MK2 Non-Turbo Engine, stick, start, figured, engine, quart, difference, noise, acceleration, pressure, means, overfill, make, knew, read, ticking, apparently, hunt, time, code, block, amount, size, 2200, edit, ideas, swap, station, shut, settle, picking, wiped, pulled, mkii, bought, good, synthetic, changed, stuff, couple, added, question, checked, filter, clean, stupid, days, dipped, poor, hard
- So a couple days after picking up my MKII, I changed the oil and filter. I bought a 5 quart jug of some good synthetic stuff and put 4.5 in. Start it up to mix it around, shut it off and let it settle a little. Pulled the dip stick and wiped it off, didn
