AI智能索引来源:http://www.mr2.com/forums/threads/58647-injector-sizes-for-5sfe
injector sizes for 5sfe
injectors, plan, injector, thought, 5sfe, mods, pennieless, toyota, factory, make, use?], cold, homemade, intake, convertor, gutting, problem, install, buying, camrys, gutted, engine, check, light, short, flushing, replace, bigger, sizes, flush, bench, stock, ponies, swap, beating, hardtop[i, larger, started]
    was going to bench flush my injectors then the thought hit me why not just replace them with a bigger injector while at it. I have a stock 5sfe in a 91 hardtop i plan on a gutted cat convertor , a homemade cold air intake, and whatever other pennieless mods i can do, will gutting the cat set a check engine light? ive done it on camrys with no problem. also i will plan on buying used injectors and flushing them before i install them
