AI智能索引来源:http://www.mr2.com/forums/threads/58814-How-to-Fuel-Filter
5S-FE MK2 Non-Turbo Engine How to: Fuel Filter
5S-FE MK2 Non-Turbo Engine, filter, back, lines, fuel, socket, harness, find, time, 17mm, 10mm, make, screws, side, taking, track, spacers, line, pump, changed, long, minutes, place, quick, bolts, watch, extra, wound, luck, enjoy, leakage, tools, attaching, easy, bolting, pretty, past, lost, power, block, gained, year, write-up, hope, helps, worked, hour, times, approx, running
    Approx. time: 1 hour 30 minutes (less if you have better luck than me =D) Tools needed: 10mm socket 17mm socket Socket extension Socket swivel 17mm wrench (if you have trouble getting to the fuel lines) Drain pan
