5S-FE MK2 Non-Turbo Engine Replacing Topside Injector O-Ring...
5S-FE MK2 Non-Turbo Engine, fuel, topside, injector, o-ring, rail, block, replace, underneath, appreciated, bolts, loosen, clearance, greatly, pull, attached, figure, question, leaking, thinking, replacing, intake, manifold
Have a question here...
im leaking a lot of fuel from #1 fuel injector.
Im trying to figure out whats the best way to replace the topside O-ring while the intake manifold is still attached to the block.
Im thinking that i should be able to get to the fuel rail from underneath the car, but im not too sure.
Will i have enough clearance, once i loosen the 2 bolts that keeps the fuel rail to the block, to pull out the #1 fuel injector to replace the topside O-ring?
any help is greatly
