AI智能索引来源:http://www.mr2.com/forums/threads/59513-AutoTranny-issue-in-reverse
AutoTranny issue in reverse
ticking, reverse, sound, gears, brake, fine, lower, stops, felt, transmission, thing, time, shift, suggestions, slip, plenty, good, torque, axles, start, action, moves, drive, today, finally, subside, issue, happening, mention, note, moving, checked, fluid, noise, find, rattling, happened, autotranny, process, jackstands, park, back, increase, constant, important, power, means, listened, neutral, roll
    Today i finally got everything good enough to where it was time to start moving the car under its own power. I go through the gears, and im getting this ticking sound ONLY when i go into reverse. Theres no grinding, or any noise at all when i shift into Reverse...only the ticking sound, and its constant and it doesnt increase. I can shift into neutral and it stops, go back to Park, and it stops. Only in Reverse will i get that ticking sound. I put the MR2 on jackstands to see if i could find
