timing, jumpering, bypass, mode, picture, direction, diagnostics, point, advance, problem, dizzy, advanced, wanted, issues, degrees, turn, pass, reading, advancing, correct, anymore, setting, thing
ok. so timing is set at 6 degrees right now and i wanted to advance it to 10. the problem is that the dizzy is advanced all the way and wont turn anymore to correct it. what can i do? i tried setting to tdc and advancing, still the same. it wont go pass 6. help?
ok.. after some reading, there is one thing i didnt do. i did not set the ecu into bypass mode by jumpering TE1 and E1 in the diagnostics box. can anybody point me in the right direction on how i go about doing that. a picture
