AI智能索引来源:http://www.mr2.com/forums/threads/60146-Removing-the-stock-downpipe
Removing the stock downpipe
downpipe, stock, muffler, remove, replace, work, catalytic, easier, removing, pipe, header, clamp, converter, dremel, actual, place, properly, welding, recommendation, clamping, limited, space, secondary, clamps, wanted, impossible, thoughts, advice, jack, lift
    I wanted to remove the stock downpipe so i can replace the catalytic converter that is on it. I
