AI智能索引来源:http://www.mr2.com/forums/threads/60198-Smoke-from-the-engine-compartment
Smoke from the engine compartment...
smoke, engine, battery, negative, level, caused, disconnected, cooling, coming, hood, running, charging, wrong, system, volts, fine, brakes, garage, pretty, spark, looked, compartment, burned, connected, earlier, times, lead, 11-12, ground, sw20, locate, alternator, started, moment, 3s-ge, accurately, off-position, ignition, weeks, immediately, opened, cable, voltage, measured, mark, exclamation, alternators, terminal, positive, brake
    So, I was in my garage the other day, and suddenly I noticed smoke coming through the hood of my 3S-GE SW20. The engine hadn
