AI智能索引来源:http://www.mr2.com/forums/threads/60917-engine-questions
engine questions??
sensor, opening, hose, supposed, transmission, figure, engine, bolted, hanging, guys, questions, http://i.imgur.com/zj7bsl.jpg, intake, lastly, bolt, missing, wanna, http://i.imgur.com/4hmavl.jpg, brackets, http://i.imgur.com/ixvtvl.jpg, junction, metal, wires, black, form, cables, burned, http://i.imgur.com/62sgyl.jpg, confused, temp, coolant, parts, changing, 5sfe, shape, connect, assuming, sensorundecided, causing, told, issues, acceleration, type, stock, bolt/screw, lack, part, problems
    hey guys well i had a few questions about some parts of my mr2 5SFE engine ok so i was changing the coolant temp sensor when i see a black box hanging form the cables :confused: http://i.imgur.com/62Sgyl.jpg in seems to be burned and in bad shape... i wonder that its for and if its like a stock oem part?? next is the lack of a bolt/screw (or so it looks) and a transmission sensor of some type. there are some wires that can be seen there and am assuming they connect to the
