5S-FE MK2 Non-Turbo Engine trans rebuild
5S-FE MK2 Non-Turbo Engine, synchros, trans, rebuild, kinda, full, smooth, gears, notchy, grinds, shifting, weld, daily, worthy, hear, suck, difs, welded, drifter, tyte, assume, make, tackle, easily, removable, engine, thinking, redo, removed, press, split, case, hard
hey, im thinking about trying to redo the synchros in my s54 trans. the trans would be easily removable seeing how the engine isnt in there right now :P
if the case isnt hard to split, and nothing needs a press to be removed i may tackle the synchros while i can.
has anyone done it before?
i dont need a full rebuild. nothing grinds, but the gears arent smooth while shifting. its kinda notchy, and i can only assume its synchros.
could even weld the dif while its out and make a mad tyte
