AI智能索引来源:http://www.mr2.com/forums/threads/63910-Swapping-transmission-diffs
Swapping transmission diffs?
diff, transmission, diffs, swap, camrys, e153, 4cyl, automatic, manual, period, time, instance, transmissions, swapped, swapping
    Does anyone know if diffs can be swapped between transmissions? For instance could I swap the diff from an S53 (or whatever came w/ the 3rd gen MT 4cyl camrys) with the diff from an E153, or even swap the diff from an automatic transmission of that time period into a manual transmission?
