AI智能索引来源:http://www.mr2.com/forums/threads/65193-code-26
fuel, pressure, code, line, vacuum, unplugging, made, sensor, cold, start, sound.ugh, unplugged, rpms, showed, regulator, engine, nada, advice, mr2ersd, fellow, takin, missing, plugging, vsvs, ethirr.wtfwtfwtf, change, computer, throwing, issue, wiring, idles, times, differently, rich, thingrolleyes, mixture, problem, setup, jump, wich, small, started, swallows, giving, good, diagnostics
    ok computer is throwing code 26. (wich is good cuz last wiring setup wasnt doing any thing):rolleyes: rich fuel mixture problem. BUT..........i have a low fuel pressure issue ( i think) it idles differently at times itll jump up to almost 2k then go under 1 and giving it any gas small or big it just swallows air i started doing diagnostics. unplugging the vacuum line from the fuel pressure regulator showed no changes in rpm or engine sound.:ugh: unplugging the oxy sensor made my
