HomeMKII MR2: Coolant Flush page 2Bleeding Air out of the MR2 Cooling SystemVisit Homepagewww.sourcecustoms.comMR2 Floor Mats Available Now!!Visit Homepagewww.sourcecustoms.comMR2 Floor Mats Available Now!!Visit Homepagewww.sourcecustoms.comMR2 Floor Mats Available Now!!Visit Homepagewww.sourcecustoms.comMR2 Floor Mats Available Now!!Toyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
coolant, system, flush, bolt, link, engine, lines, clear, water, questions, couple, burping, matter, long, bleeding, burp, looked, burped, fully, degreaser, part, http://www.lovehorsepower.com/mr2_docs/mr2_bleeding_cooling_system.htm, cooling, minutes, follow, crater, change, understand, recommended, money, screwing, paranoid, heard, blowing, headgasket, poured, open, heater, bolts, core, mkii, mention, http://www.mrtwo.net/mr2modproject/service/coolantflush/coolantflush2.htm, page, draining, read, time, newb, links, post
- I have a couple coolant flush questions. I am a newb and this is the first time me doing a coolant flush. I have read a couple links and i will post them below. For when you are draining the system, does it matter which bolts you take out first, then second, then third? Do you take the Rad, then lines, then heater core, then engine bolt?
On this link, there is no mention of engine drain bolt, With the car jacked up on rear, there would be no need to open the
