AI智能索引来源:http://www.mr2.com/forums/threads/66924-Wideband-Sensor-Installation-HELP%21%21%21%21%21
Wideband Sensor Installation, HELP!!!!!
sensor, install, wideband, turbo, closer/away, installin, differents, helps, air/fuel, timing, reading, 36inches, installation, manual, turbocharged, inches, make
    I buy a AEM Wideband and going to install the sensor and the manual says that need to be install on turbocharged car the sensor 36 inches after the turbo, does make any differents installin the sensor closer/away from the turbo? if is install 36inches, does after the timing lag of the reading of the air/fuel mix? please helps! Thanks!
