AI智能索引来源:http://www.mr2.com/forums/threads/67651-how-to-determine-compression-ratio
5S-FE MK2 Non-Turbo Engine how to determine compression ratio?
5S-FE MK2 Non-Turbo Engine, standard, .020, .50mm, compression, oversizes, ring, 10.51, bearings, group, pistons, complete, 1.50, calculate, bearing, .25mm, determine, ratio, .010, 9.51, thrust, made, japan, washer, measurement, diameter, 4.00, king, pins, 87.10, main, engine, apply, wanna, atlease, higher, thinking, rebuild, gonna, chart, size, judge, oversized, stardard, .050mm=.020, rings, .0??mm
    Ok so I
