coolant, firewall, template, core, tubes, hole, outline, pulled, heater, replaced, grinding, trace, plan, coming, undecided, metal, sheet, back, piece, wheel, making, time, miles, 110k, years, paper, forms, located, cutting, replacement
I have pulled the heater core and replaced it according to the BGB 7 years and 110K miles ago. Its time to do it again. Has anyone ever pulled it out and replaced it by cutting a hole in the firewall?
I have a replacement core. I am making up a paper template that forms the outline and located via the coolant tubes. I plan to put the template over the coolant tubes and trace the template outline on the firewall.
Then cut the firewall with a grinding wheel. It will all go back
