AI智能索引来源:http://www.mr2.com/forums/threads/68284-Oil-leak-again%21
5S-FE MK2 Non-Turbo Engine Oil leak again!...
oil leak, 5S-FE MK2 Non-Turbo Engine, time, fixed, area, bottom, good, pump, gasket, head, blown, sludgy, stuff, appreciated, pics, belt, timing, water, replaced, started, distributor, attached, problem, soaked, showing, checked, valve, 3sgte, speed, swap, leak, oils, leaking, year, cover, found, minor, giving, 5sfe, headache, leaked
    For the 3rd time now the oils leaking again, it
