AI智能索引来源:http://www.mr2.com/forums/threads/70252-Need-help-diagnosing-ignition-problem
5S-FE MK2 Non-Turbo Engine Need help diagnosing ignition problem
5S-FE MK2 Non-Turbo Engine, coil, back, plug, igniter, start, wire, appears, specs, good, fuse, 7.5amp, outlined, coming, thing, resistance, tests, inthe, expensive, test, method, find, part, greatly, appreciated, advice, swap, suspicious, engine, broken, wires, harness, wiring, peeled, inside, internet, poking, loss, occasionally, driving, attempts, starting, instantly, lose, tachometer, power, months, problem, ignition, diagnosing
    I have a 1991 n/a MR2 that won
