Warning: SimpleXMLElement::asXML(E:\phpstudy_pro\zhinengdaohang\sitemaps\sitemap_121.xml.tmp): failed to open stream: Permission denied in E:\phpstudy_pro\zhinengdaohang\dd.php on line 1330
5S-FE MK2 Non-Turbo Engine 93 speedo sensor help! - AI智能索引
AI智能索引来源:http://www.mr2.com/forums/threads/70282-93-speedo-sensor-help%21
5S-FE MK2 Non-Turbo Engine, sensor, wires, problem, control, cruise, speedo, good, contact, cleaned, connectors, pulled, made, female, caps, work, input, simple, electronic, cleaner, ideas, male, rolleyes, mr2s, fired, rebuilt, 5sfe, info, learned, obtain, impossible, motor, speedometer, point, shoved, back, located, worked, engine, tranny, connects, plastic
    So I
