nitrous, fuel, bottle, pressure, recommend, safety, shot, power, turn, gear, intake, things, system, single, switch, spraying, make, stock, pump, feeds, pedal, rpms, loose, time, traction, spray, heat, window, important, needed, features, missed, risk, recommended, mods, installed, adding, turbo, start, adder, running, minimum, money, degrees, evenly, late, torch, return, handy, cold
I wrote this to clear some things up. Its getting late so I might have missed some things. I will return to fill in any questions or spots missed. Not to mention there is not a single sticky on Nitrous in the nitrus section?! :lol:
To start things off.
First off if your wanting to learn about Nitrous please do your research. As recommended by every single person I have ever met running Nitrous in a turbo or n/a mr2 a 75 wet shot is a safe start and where you need to be unless you have
