AI智能索引来源:http://www.mr2.com/forums/threads/71083-mixture-goes-Lean-at-cold-start
3S-GTE USDM Turbo Engine mixture goes Lean at cold start
3S-GTE USDM Turbo Engine, start, mixture, cold, lean, supplying, injector, check, open, engine, idle, fine, running
    went I start the engine on cold start at idle the mixture is fine but went I start running the mixture goes Lean, why is that? I check with supplying 12v the cold start injector and it open
