AI智能索引来源:http://www.mr2.com/forums/threads/73532-5sfe-new-plug-wires
5S-FE MK2 Non-Turbo Engine 5sfe new plug wires,
5S-FE MK2 Non-Turbo Engine, wires, plugs, thing, forgot, bump, switched, nology, jumping, missfire, mention, change, changed, coil, appreciated, manifold, matters, love/hate, putting, inside, grounded, wire, bolts, intake, ground, slow, shift, lowness, perfectly, good, 5sfei, plug, working, new/used, great, felt, response, tiny, normal, explain, care, 5sfe, bogs, jump, makes
    (5sfe)I had some good perfectly working wires that i had switched out with new/used nology wires. After i switched the wires, the response felt great, but only thing was whenever i would go over a bump, after that bump (because i slow down because of lowness) I would shift to second, and when the rpm goes a tiny bit under 1k in second, it bogs and makes my car jump a little, where as when i used to do it with my old plugs and everything would be normal. Anyone care to explain why it keeps
