AI智能索引来源:http://www.mr2.com/forums/threads/7396-Modifying-sway-bars
Modifying sway bars
sway, heat, bars, holes, treat, stock, rear, adjustable, weld, controlled, cooling, started, thinking, hardness, treated, whiteline, atlanta, re-treated, preserve, afternoon, lowering, adequate, raised, adjust, length, arms, make, wanted, welding, plate, stiffer, compensate, modifying, geometry, change, welded, understeer, reduce, made, tack, plates
    I wanted to make an adjustable rear sway bar by welding on a plate that had several holes which could be used to adjust the length of the arms. I just want my rear sway bar to be a little stiffer than stock to reduce the understeer. I made some plates and tack welded them to a stock bar. I raised the holes too, to compensate for the geometry change that you get when lowering the car. But then I started thinking about the hardness and heat treat of the sway bar. Is it OK to TIG weld a sway bar?
