AI智能索引来源:http://www.mr2.com/forums/threads/74868-Electrical-Short-When-Trying-To-Start
5S-FE MK2 Non-Turbo Engine Electrical Short When Trying To Start
crank, electrical, fire, short, starter, 5S-FE MK2 Non-Turbo Engine, start, looked, cable, turned, engine, sounded, smoke, fine, parked, solenoid, wire, mechanical, disconnected, battery, fast, smoking, strange, luck, internal, suggestions, ideas, problem, change, making, noticed, throttle, noise, happened, figured, turning, time, hand, sort, knock, year, thing, plugs, pulled, check, 1991, picked, 5s-fe, bought, tells
    Just picked up a 1991 NA, 5S-FE. The guy from whom I bought it tells me that it ran when he parked it about a year ago, but sounded like it had a knock of some sort, so he parked it. First thing I did was check the oil, then pulled all the plugs to have a look at them. While I had each plug, I poured a capful of oil in each cylinder to make sure it was at least a little
