AI智能索引来源:http://www.mr2.com/forums/threads/75011-How-to-compression-test
5S-FE MK2 Non-Turbo Engine How to compression test?
5S-FE MK2 Non-Turbo Engine, compression, test, injector, start, connector, cold, connecter, easier, locate, distributor, suppose, 5sfe, motor, srry, noobie, questio]n, part, disconnect, engine
    Srry noobie questio]n. How do you Compression test on a 5sfe motor? the only part I dont get is that wat am I suppose to disconnect from the engine before doing it. The bgb says cold start injector connector n distributor connecter. I cant locate them or are there an easier way?
