5S-FE MK2 Non-Turbo Engine afc tps issues i think
5S-FE MK2 Non-Turbo Engine, 3sgte, rich, datalogging, back, randomly, fires, lean, freaking, wideband, detonation, list, injectors, tach, adapter, ideas, apexi, supra, manifold, helps, full, turbo, leaning, retarding, noticed, install, signal, basicly, switch, issues, 5sfet, running, timing, great, working, brick, boost, btms, issue, 100%, normal, main, moving, wall
ok so the 5sfet is running , but thats about all its doing... while i was doing the afc install i noticed that the tps signal to the afc is basicly a on off switch... like i only have 0% and 100% there is no in between is that normal?
but moving on to my main issue, btm
