5S-FE MK2 Non-Turbo Engine Running on 2 cylinders. Need help asap
5S-FE MK2 Non-Turbo Engine, cylinders, found, fuel, running, distributor, poked, crap, letting, runs, motor, popping, acceleration, poor, hesitation, pump, step, injectors, appreciated, spark, filter, problem, hope, insides, test, compression, asap, bought, turbo, tampered, igniter, coil, ignition, replaced, rotor, plugs, wires, ahead, piece, figured, broken, remove, changed
Just bought a 93 non turbo and it was running like crap. Did a compression test first off to get some hope and it is 210 on all four cylinders. So then i poked around and found out that the insides of the distributor had been tampered with and the piece that said
