AI智能索引来源:http://www.mr2.com/forums/threads/75887-Info-on-removing-spark-plug-tubes
5S-FE MK2 Non-Turbo Engine Info on removing spark plug tubes
gaskets, ignition, spark plug tubes, spark plugs, valve cover, 5S-FE MK2 Non-Turbo Engine, tubes, spark, owner, remove, sitting, plug, questions, picked, grips, vice, socket, toyota, cylinder, fipg, black, reseal, stuff, read, torquing, process, arise, torque, specific, installed, safe, attempt, original, previous, left, garage, filled, removing, sadly, 2002, leave, loose, plugs, taking, debris, avoid, crack, info, brand, s2000
    I got rid of my 91 (sadly) and picked up a 93. All of my spark plug tubes are filled with oil (the previous owner, who is the original owner just left the car sitting in his garage since 2002, when he picked up a brand new S2000). So, my questions are: 1) Do I need to remove the oil sitting in the tubes before I attempt to crack them loose? 2) Can I leave the spark plugs in when taking out the tubes to avoid debris falling into the cylinder? 3) Can I use Toyota FIPG (the black stuff
